annoying coolant leak
Old Mar 22, 2016 | 08:40 PM
98satsl1's Avatar
Default annoying coolant leak
I have a 98 sl1 sohc. I have a coolant leak that is driving me crazy. I think it's coming from the intake manifold at the coolant passage. I have replaced the intake gasket twice. First I used a victor reinz and then a felpro. Still having the problem. Not sure what to do next. Has anybody had this same problem. Please let me know what you did to fix this.
Old Mar 23, 2016 | 10:59 AM
Is there a written procedure you are following?
98 is prior to the plastic intake manifolds so well known plastic intake manifold is not in play here nor is the repair kit for it.
Are you getting the mating surfaces absolutely clean before replacing gasket?
You must be very careful to get the gasket lined up perfectly or it will leak
Are you following bolt order when tightening and torque specs?
Have you checked to make sure the manifold itself is not cracked in that region?
Or if there is a slight uneveness at the point of leakage?
Use the felpro gasket going forward.
Aside: these intake manifolds on the SOHC were notorious for incurring damage near the #1 cylinder and creating leaks, misfires, high idle. Did the original I/M gasket show signs of distortion near #1 cyl?
The above barrage of questions may sound as though I am interrogating you in a mean spirited way. Nothing further from the truth. Just in a hurry and not taking the time to word it all pretty -- so please do not take offense.
Old Mar 23, 2016 | 07:57 PM
98satsl1's Avatar
No offense taken. I appreciate the response.
I've done pretty much everything you described. Surfaces clean, gasket slides over studs. No lining up the gasket. Torqued from center out in 4 steps. I used a felpro gasket. I guess I need to take it off again and check for cracks.
What damage are you talking about at cyl 1? Thanks again for your reply.
2000L300
Oct 31, 2010 03:58 PM
bullet120
May 3, 2009 05:37 PM
Icurl4
Feb 19, 2007 08:20 PM
rgjoslin
Feb 11, 2007 10:31 AM
LS2guy
Aug 22, 2005 03:17 PM
