AC stop leak in a can -- anyone used it?
Old Jul 13, 2014 | 10:19 PM
derf what's the word on your a/c? Hope you got it running, I bet it's been needed. Could hardly live without it around here.
Old Jul 14, 2014 | 05:33 PM
not attempted yet. Other priorities. Driving my 97 xc2 in which the ac still works
Old Jul 15, 2014 | 08:20 AM
Gotta have working a/c this time of year. The next two to three days here should be fairly comfortable here. I got two vehicles to work on and a yard to mow. I'm going to take advantage while I can!
Old Jul 16, 2014 | 06:57 AM
Bill Berger's Avatar
Here's a product that guarantees to stop a leak in your a/c system, or your money back. Might be worth a try if someone has a small leak.
Old Jul 20, 2014 | 09:48 PM
C6vette's Avatar
Derf,
I work on commercial A/C for a living so I have never used the stop leak. However, Being in this business for 35+ years I do have some experiance with auto A/C. Your leak very well could be in the evaporator but a leak can and very often will be in the compressor seal on a car this age. There is a seal (O ring) on the compressor shaft that will deteriorate over the years, usually from lack of use as the refrigerant oil keeps it soft. I have found that dye does not always appear when these seals leak.
Best to replace the compressor if you do find a leak in it.
Old Jul 20, 2014 | 10:34 PM
C6vette's Avatar
OK derf,
Just talked to a friend of mine who does auto A/C work. He stated (as you probably know) pulling the evap. to see if it is leaking is a very big job. If your evaporator is leaking you can tell by (depending on the amount and type of dye being used, UV is best but requires goggles and special light) you should be able to see samples of the dye in the condensation from the car or the actual end of the drain tube. UV will also be visible at the compressor shaft but other types are very difficult to see at the shaft. While he is not an advocate of the sealer he said if your compressor shaft is leaking the sealer may well seal the o rings and stop the leak, for how long he has no idea. He said, drain the system, do not draw a vacuum because if there is a leak you will draw atmosphere via the leak. add the "exact" amount of R134A required plus your sealer. Before checking the charge, run your A/C now and check the suction line for temperature. If it is very cold to the touch yet you are getting poor cooling you have issues with the "blend doors". Other wise, do the drain and refill with sealer then run the A/C for a while. It may seal the compressor for you.
Hope this helps.
Old Jul 20, 2014 | 11:58 PM
C6,
Thank you for your wealth of info!! I have a UV light and goggles so I can check the drain tube area. I will also poke around the compressor a bit closer (even though the seal is internal).
I've actually made a point of running the AC in the winter on all my cars to keep all the rings from drying out but anything's possible.
I don't believe it to be a blend door issue as I always have gotten ice cool air once fully recharged.
I understand your point about not wanting to suck in air during a system evap, but I have found it very difficult in the last few years to get the system to accept any refrigerant when it's full of air. When some one evacs it first it goes nice and smooth -- and yes they are adding the oil.
Thanks again and I'll keep you all posted
Tires
Dec 17, 2012 10:18 PM
cadman33619
Sep 9, 2012 10:55 AM
jeffgilbert
Apr 16, 2009 05:49 AM
robot
Jun 25, 2008 07:21 AM
Dave C
Jan 13, 2008 12:17 PM
