97 SL starting problems
Old 01-01-2008, 04:29 PM
dlshoema's Avatar
When I start my car sometimes it acts like the battery is dead (no lights or starter turnover). However if i turn the key off and try again it will usually start on the next try or two. I had the battery tested and it is fine. The starter is only a couple of years old at the most. Does anyone have any ideas. I'm thinking that it is an ignition problem but do not know much about it. Edited by: sw2cam
Old 01-05-2008, 09:13 AM
Check battery cable ends for corrosion damage and the battery terminals themsleves for corrosion buildup. If it is an AC/Delco battery, inspect the + terminal very closely -- they tend to leak acid where the terminal comes through the battery casing.
Also check the ground connection to the frame (the other end of the - battery cable. This needs to be a good connection to complete the electrical circuit.
Definitely sounds like a poor/intermittent electrical connection issue
DerfEdited by: derf
wily420
01-13-2008 12:06 PM
nemo
01-11-2008 09:30 AM
imaukfan
09-24-2007 03:45 PM
rjohnson
02-27-2007 01:00 AM
hot2cool
10-20-2005 07:02 PM
Quick Reply: 97 SL starting problems
