96 sl1 burning major oil....help
Old Feb 21, 2010 | 02:36 PM
jhaney44's Avatar
Default 96 sl1 burning major oil....help
i noticed a ticking about 2000 miles ago and oil consumption was up to 2 quarts every 500 miles. i had a few people tell me it needed a valve job so i put on a completely remanufactured head including valves seals and cam. it actually got worse with the new head. now blows more smoke and burns 2 quarts every 150 miles, plus it still has the tick that i was told was a burnt valve in the old head. triple checked timing. it has 125k miles. piston rings are my only guess, but looking for any input. thanks.
Old Feb 21, 2010 | 04:07 PM
So who did the wet/dry copression test on this engine before it was tore down. Who didn't replace the timing chain when the engine was tore down.
Old Feb 22, 2010 | 05:30 PM
jhaney44's Avatar
i did actually replace the timing chain while it was apart, forgot to mention that. and i did the compression test myself. pressure was at about 20 to 30 if i remember right in the very front cylinder. pressure stayed the same both wet and dry. all 3 other cylinders were around 180.
dwd375
Aug 2, 2015 09:42 PM
funkmasterSC2
May 30, 2008 03:32 PM
Playincard
Sep 5, 2007 12:55 AM
mom7x
Aug 28, 2007 05:42 PM
thewearhouse
Sep 6, 2006 06:04 PM
