96 Saturn SL clutch slipping
Old Feb 21, 2010 | 10:11 AM
dkriz's Avatar
Default 96 Saturn SL clutch slipping
Can anyone tell me if there is a manual adjustment on the clutch? I cant find any external
ly. Nothing seems to be wrong with the hydraulic actuator side of it & the fluid level is fine. Free play seems short & the clutch slips, mostly on accelleration in 2nd & 3rd gear. Is there a manual adj. or is the clutch plate needing replacement. Any help is much appreiciated . Thanks
Old Feb 21, 2010 | 11:09 AM
The answer is no
Old Feb 21, 2010 | 11:11 AM
dkriz's Avatar
By the way, I had to repost this question because for some reason my thread from last night got deleted?
dkriz's Avatar
Originally Posted by sw2cam
The answer is no
Does that mean there is no adjustment? Or nobody knows how to adjust the clutch?
Old Feb 21, 2010 | 11:53 AM
hoseppi's Avatar
There is no way to manually adjust it. It is hydraulic, and compensates for clutch wear automatically. If the clutch is slipping you need to replace it with the pressure plate and release bearing.
Old Feb 21, 2010 | 12:17 PM
dkriz's Avatar
Thank you.
Old Mar 15, 2018 | 10:20 AM
Jiminix's Avatar
Default Got the same problem
I just posted how my 2000 Saturn clutch is slipping again I replaced the clutch throw out bearing and pressure plate . About a month later it started slipping again and I replaced the hydraulic clutch assembly. That was less than 2 years ago and it's slipping again I know the parts can't be worn out but with no adjustment on the cable I'm not sure how to fix it any help or advice would be greatly appreciated thanks
Old Mar 16, 2018 | 12:31 AM
  • 2000 - 2002 Have the self-adjusting hydraulic POS.
Quote from wikipedia.net
junior
Dec 2, 2009 06:34 AM
dgoodmand
Apr 1, 2009 10:12 PM
Stefi
Aug 2, 2008 09:52 AM
2000saturnsl2
Mar 16, 2008 04:28 PM
iw433
Mar 24, 2005 08:23 PM
