95 Saturn SL - OVERHEATING!!!
Old Oct 22, 2012 | 11:19 PM
codyraypitts's Avatar
Default 95 Saturn SL - OVERHEATING!!!
I own a 1995 Saturn SL that has a cooling fan problem. So when ever i drive up a hill or on the freeway it gets to really high tempatures and wants to over heat.
Okay so i've basically have tried everything to fix the fan.
I replaced:
Cooling fan
Overfill Cap
Engine temp Sensor
Coolant temp sensor
Fan relay
cooling fan fuse
Even with the a/c on the fan still wont run. So i checked the voltage of the wire going to the fan and there was no power. So i took the relay off and i jumped the relay with a paper clip... IT TURNED ON!!!
But that still hasn't fixed my problem. Jumping the relay makes the fan stay on all the time(even when the car is shut-off)
So what else do i need to do to get the fan moving when its suppose too, like when i turn the a/c on and my car gets really hot?
Old Oct 23, 2012 | 11:27 AM
This is your THIRD post on this issue.
I deleted the other two threads.
Multiple post again again and you will be banned
Old Oct 23, 2012 | 12:47 PM
Check the following fuses in the underhood junction block --> PCM 1 and PCM B (both are 5amp).
Based on your comments, there's one other possibility ... bad PCM, but I'd wiggle the heck out of the connectors for the UHJB and the PCM first.
Old Oct 24, 2012 | 09:50 AM
Maybe stop in the new member area and give yourself an intro.
Old Oct 24, 2012 | 08:16 PM
coolant temp sensor from GM dealer?
How high on the dash temp gauge does the reading get?
does the car ever actually overheat?
does the fan ever kick in?
Old Oct 24, 2012 | 09:15 PM
C6vette's Avatar
I could be wrong but---If you are driving at highway speeds and the car overheats you may have other issues. At highway speed more air is flowing through the radiator than the fan or fans can supply themselves. The fan is effective at low speed or idle much more than highway speed. Perhaps your Saturn is different but I suspect not.
Old Oct 30, 2012 | 05:47 PM
keith's Avatar
Your fan needs to work anytime the AC is on. You need to check to see if there is another relay that also controls the fans, usually there are two or three when you have AC, one turns on one fan when the coolant temp gets too high, and one turns on both fans when the AC is turned on. The third may also be for the AC or it may be a low/high relay.
Your symptoms however indicate the cooling system is not holding pressure. That is usually due to the cap, but it could be the coolant reservoir itself, it might have a crack or for some reason is just not allowing the cap to seal. If your not loosing coolant, then the issue has to be above the waterline.
Old Oct 31, 2012 | 09:36 AM
This statement from your post:
Un-Quote:
Says the relay is not turning on.
So jumping the relay would indeed make it work, or make the fan work. Which is what you want to make work.
However it is the relay that is not working. Changing the relay did no good, so it is probably not a defective relay.
What you have not done is to verify that there are the proper voltages and signals to the relay to make it function.
You need to purchase a repair manual for your car that gives the wiring diagram for the relay thus thus the information to trouble shoot why the relay does not turn on.
griffinbret7
May 2, 2015 11:04 PM
dy1977
Mar 11, 2009 11:00 AM
gbelous
Jun 26, 2007 07:08 AM
talldredge
Nov 3, 2006 10:38 AM
U_turn
Aug 27, 2005 05:14 AM
