94 SL1 Electrical Problem
Old May 11, 2010 | 05:24 PM
SaturnATV's Avatar
Unhappy 94 SL1 Electrical Problem
I have a 94 SL1. It's not my every day driver, so was sitting for a couple weeks and when I went to start it it wouldn't quite turn over, like the battery was dead. I took the battery out and charged it but when I reconnected it nothing happens. No lights, no fan, no radio, no ignition click, nothing.
I've put a voltmeter on the battery and am getting over 12v. Checked my fuses and am getting power out of the fuse box just fine. Verified that the ground is good.
Any ideas? Is it possible I've blown the computer somehow? Would that cause these symptoms?
Thanks,
Bob
Old May 11, 2010 | 05:50 PM
Check pos battery cable for tightness and corrosion (signs of acid getting sucked up into the cable).The voltage may be there but the current necessary to run things may not due to a damaged cable.
Also, check the V across the batt when trying to start (requires a friend or long DVM leads) -- your battery itself may be the issue.
Can the car be jump started?
Old May 22, 2010 | 12:20 PM
SaturnATV's Avatar
Thanks. I had to rebuild the ends of the battery cables, but it works fine now.
Old May 22, 2010 | 02:55 PM
Not too many "rebuild" their cables these days -- takes me back to a gentler era. Hope you used Cupresol or some such similar product to protect your new connections.....
Old May 22, 2010 | 05:07 PM
Never heard anyone say they "rebuilt" battery cables when all they did is replace the terminals.
refinnejm
Jan 16, 2011 06:36 AM
ForgottenOne
Oct 19, 2009 12:50 PM
royphotog
Dec 19, 2007 07:00 PM
MCapone
Feb 22, 2007 05:38 PM
airedale
Jan 31, 2006 10:12 PM
