92 saturn lost all power
Old Jan 8, 2009 | 09:09 AM
m-8turbo's Avatar
I have a 92 saturn was running great the all the sudden loss of all power wont do anything help!
Old Jan 8, 2009 | 09:03 PM
jfm567's Avatar
Look under the hood and check to see if the spark plug wires are touching the exhaust manifold. happened to me and killed all of its power. (until i got the wires replaced of course.)
Old Jan 9, 2009 | 08:13 AM
m-8turbo's Avatar
I went home last night wiggled around the battery cables and I again had power cables dont seem corrodided or dirty or even loose. I dont understand if the car started right up and I was just sitting at a stop sign how it could instantly die and have nothing and it have something to do with the battery cables. Car must not run at all after started without a battery like old cars.
Old Jan 9, 2009 | 09:04 AM
For some reason, Saturn is plagued with battery cable issues. Whenever anything of an electrical nature goes wrong, the first thing to do is shake the cables, flex them at the connection points, and replace them if there is even a suspicion of wear or corrosion.
Old Jan 9, 2009 | 10:17 AM
Low Saturn's Avatar
Because some A/C delco batteries used to leak acid through the positive terminal into the cable. This causes the cables to corrode internally. Vibration from the engine running causes a poor connection between the corroded and non corroded parts of the cable.
But you havent given us enough information to really give you a good diagnosis of whats wrong. Could be the cable, could be the alternator too.
cadman33619
Apr 30, 2013 09:33 AM
archer472
May 31, 2011 02:36 PM
uncljohn
Mar 19, 2010 09:44 AM
DonP
Mar 21, 2007 02:17 AM
agewood
Jan 14, 2007 12:25 AM
