91 saturn coupe twincam.
Old Aug 22, 2011 | 09:26 PM
robert.jr33333's Avatar
Default 91 saturn coupe twincam.
hi,
i have a 91 saturn coupe that has been acting weird. When you start it up and try turning on the lights or any power thing on it, it starts to die. And my turn signal lights, light up when i push on the brake. Does anybody have an idea what could be the problem? i already cleaned the ground contacts but i didnt clean the ones on the back of the motor yet.
Old Aug 22, 2011 | 10:11 PM
It sounds like you have one (or more) power connections that are going bad.
Charge your battery overnight, to make sure it is fully charged.
Check the battery cables (the big ones) by flexing them -- if they have become brittle internally, replace them. The battery acid will sometimes penetrate under the cable jacket. and begin to destroy the copper cable from the inside, much like termites do to a 2x4 in your house.
Check the various ground connections on the sub-frame of the car to make sure they are tight and making good contact
Michelle100
Jun 3, 2010 07:01 AM
lukesteeler89
Mar 19, 2009 04:14 PM
chriSL2
Dec 23, 2008 05:35 PM
secondsaturn
Sep 17, 2007 08:51 AM
blksti04
Mar 1, 2007 05:21 PM
