2007 Vue 2.2L 4 speed automatic to 2003 2.2L?
Old Aug 7, 2016 | 09:24 PM
Avnav8r's Avatar
Default 2007 Vue 2.2L 4 speed automatic to 2003 2.2L?
Hello,
Is it possible to put a 4 speed automatic transmission from a 2007 Saturn Vue 2.2L into a 2003 Vue 2.2L with a VTi? Like many who owns(owned) this model Vue, my Vti went out. Let me know and thanks!
John Stokes
Old Aug 8, 2016 | 11:06 AM
Maybe (not sarcastic).
Would THINK the tranny would bolt up.
What I don't know is what automatic they used in 2007.
The issue will probably come down to ECUs, BCMs, TCMs, communications, and wiring harnesses.
You'll need the 2007 ECU from the 2007 Auto VUE to send signals to the 2007 TCM, probably through the 2007 BCM. I'm going to make a wild guess that the TCM BCM, ECU changed (check part numbers)
Equally as significant, I believe the communications bus between the modules
changed from GM's implementation of basic OBDII compliant communication to CANbus, a different variant of OBDII that I THINK was required in 06 or 07. Point being I DO NOT BELIEVE any of the modules in your 2003 will communicate with each other, BCM, ECU, TCM, etc unless you swap the entire wiring harness from the 2007 to the 2003 -- making the 2003 think it's a 2007, basically, However, you may run into issues if the 2003 lacks outputs the 2007 ECU requires OR the 2007 harness does not have provisions to connect up all of the 2003's options.
The ECU and BCM would need to be flashed to match your vehicle's options. Taking the TCM from the 2007 would also be required. Some are inside the tranny.
USE THE ABOVE AT YOUR OWN RISK
I AM NOT A SWAP EXPERT AND NOT RESPONSIBLE FOR WHAT CHANGES YOU DECIDE TO MAKE TO YOUR VEHICLE(S).
PERFORM YOUR OWN FOLLOWUP RESEARCH TO CONFIRM OR DISPROVE ANY AND ALL STATEMENTS MADE ABOVE.
Old Aug 8, 2016 | 11:37 AM
Avnav8r's Avatar
Thanks Derf! I'll pass this on to my mechanic. He's pretty skilled and may be able to pull off this transplant.
kaburns519
Jun 3, 2015 12:58 AM
tim
Jan 14, 2012 10:11 AM
denverboardguy
Jun 11, 2009 04:59 PM
TWOOD
Mar 19, 2009 04:31 PM
bigevegas
Feb 23, 2009 07:24 PM
