2005 saturn vue a/c problem
Old Aug 28, 2009 | 10:50 PM
mike2009's Avatar
Red face 2005 saturn vue a/c problem
hello every one i got problem with 2005 satrun vue a/c has to much presure and wont blow good cold air it gets cold when you drive about 1 1/2 hour at idle it get hot i nned help
Old Aug 28, 2009 | 11:49 PM
did you add refrigerant to create the overpressure situation or did it just develop?
Sounds like obstruction/clog
Old Aug 29, 2009 | 01:48 AM
mike2009's Avatar
thanks for getting back to me can you be more clear about the clog ,by the way customer came in with to much presure
Old Aug 29, 2009 | 09:24 AM
so it's not your vehicle? And someone is paying you to fix this?
What are high and low side pressures with
key on engine off
and
key on engine on A/C on full cold setting?
Old Aug 29, 2009 | 11:47 AM
mike2009's Avatar
to high mor then 80 key off or on
Old Aug 29, 2009 | 11:47 PM
Please answer the question.....
key on engine off
and
That's two high side and two low side readings -- not just two low side readings....
RDARG
Jun 12, 2017 12:19 PM
dredawg10
Oct 10, 2013 07:10 PM
rayluka
Feb 9, 2009 05:43 PM
nhughes18
Mar 6, 2008 10:45 PM
nhughes18
Mar 1, 2008 11:38 PM
