2001 saturn l200 where is ects??
Old 12-17-2008, 12:32 PM
koundog1313's Avatar
i can not find the temp control sensor? can this sensor go bad and cause my car to run really rich and cause my fan to stay on constantly while running> thanks
Old 12-17-2008, 01:14 PM
The Engine Coolant Temp Sensor (ECTS) can cause all sorts of weird things to happen, depending on the mode of failure.
The sensor itself is located on the side of the engine nearest the driver. It has two wires going to the sensor. Make sure the engine is cold when you replace it, otherwise you run the risk of being burnt by the coolant. Wrap the threads of the new sensor with Teflon tape before you install it. Consider replacing the connector on the end of the wires at the same time, as they can become corroded and not make proper contact. When you buy the new sensor, make sure the tip is all metal. Some early ones had resin-tipped elements, and they were not up to the task ...
Old 12-17-2008, 10:50 PM
Low Saturn's Avatar
Old 01-30-2009, 11:13 AM
ketev's Avatar
I have a 2002 Saturn L200 and I am having a similar problem. The fans on both </span>the front and back side of my radiator run constantly only when the engine is running. There are no other symptoms and I was wondering if this is the ECTS or would this be some other problem? Also, I am not getting a check engine light or anything else.
Edited by: ketev
Old 01-30-2009, 11:37 AM
Low Saturn's Avatar
It most likely is the ECTS.
smwilli
10-28-2009 09:43 PM
imp81318
07-17-2008 08:31 PM
Ryan
09-20-2007 05:36 PM
mjeltema
11-03-2006 09:33 PM
tommy7133
03-26-2006 02:02 PM
Quick Reply: 2001 saturn l200 where is ects??
