2 brake questions for ’01 SL
Old Sep 21, 2007 | 01:36 PM
spandea's Avatar
1. How do you replace the front disc pads?
2. How do you check your rear drums if they need replacing?
Thanks for any help here!Edited by: spandea
Old Sep 21, 2007 | 11:31 PM
01dbsc2's Avatar
For the pads...
1. loosen lug nuts
2. jack vehicle up
3. remove tire
4. remove the two caliper bolts (those are on top)
5. remove the caliper
6. depress piston
7. remove/install new pads
8. re install the calipers
9. tighten down the caliper slide pins (bolts)
10. re install tire and tighten the lug nuts
11. lower vehicle and double check the tire
rear drums
follow the same procedure until step 4
loosen the star wheel behind the brake assembly
and then you should be able to get the drums off. i have done these several times, but i have trouble explaining them. check out a haynes or chiltons manual.
hope this helps.
Dont hold me responsible if anything happens to your car, your doing the work not me. Also you should always have the rotors checked for warping, and or cracking, and or thickness of the rotor.
Old Sep 23, 2007 | 09:08 AM
spandea's Avatar
01dbsc2: thats for the info. of course i won't hold you responsible for anything! hehehe. i will replace the pads today. thanks again!
mjmeredith
Sep 21, 2008 07:04 PM
soxman
Apr 12, 2008 03:13 PM
secondsaturn
Sep 24, 2007 07:49 PM
redcannon
Jun 10, 2007 04:11 PM
elnino
Jun 5, 2007 09:01 PM
