1997 Saturn SL2 Help
Old Sep 3, 2009 | 07:20 PM
patocon92's Avatar
Default 1997 Saturn SL2 Help
I need help with my 97 saturn. it starts just fine in the morning but after I run it I have to let it sit for 1-2 hours before the engine will turn over again, please help.
Old Sep 5, 2009 | 10:18 PM
Question -- are you saying that after you run your car it :
1) The starter will not turn the engine without waiting 1-2 hours ... or
2) The starter turns the engine, but the engine will not run
Old Sep 6, 2009 | 07:15 AM
hoseppi's Avatar
Smile Hot start problem
If the starter turns the engine over easily but the engine won't start (especially after the engine is already warm), it is probably the coolant temp. sensor. That model came with some type of composite sensor which usually develops cracks. The newer sensors are all brass.
Old Sep 6, 2009 | 11:27 AM
Hoseppi is correct in his statement.
Replacement Coolant Tempersture Sensor (CTS) is about $14usd at AutoZone or similar stores.
Old Sep 7, 2009 | 01:50 PM
patocon92's Avatar
It's that when the engine is warmed up the starter can't turn it over
Old Sep 7, 2009 | 03:17 PM
Check battery
if battery passes load test, replace starter
Old Sep 8, 2009 | 09:56 PM
patocon92's Avatar
Thank you so much for your help
Old Sep 13, 2009 | 02:49 PM
Check for corrosion inside of the positive battery cable, and replace if needed.
randolphjones
Jan 9, 2013 02:27 PM
scottys92
Audio/Visual Electronics
Aug 5, 2012 12:32 PM
sadurnSC2
Apr 25, 2008 06:36 PM
satty_kingsb
Apr 22, 2008 06:06 PM
Schmidty
Feb 3, 2008 06:35 PM
