-   Engine & Internal (https://www.saturnforum.com/forum/engine-internal-16/)
-   -   New here and have a BIG PROBLEM! (https://www.saturnforum.com/forum/engine-internal-16/new-here-have-big-problem-1364/)
SL2510 Sep 20, 2007 05:57 PM
Hey ya'll..
I have a few questions.. ok
So I have just boughta 97' SL2.The problem isthatit isntrunning right now(current condition I bought it). I took it to the mechanic, and he said something about a 'Cylinder Wall Head' being cracked.
Now I know what the Cylinder Wall is.. but not the 'cylinder wall head'. I'm assuming he is talking about the cylinder wall where it meets the head?
Anyways.. he qouted me $1200 parts and labor, and I just wanted to know if I could purchase a new block from a diff model (like an sl1), and if it would just bolt right on (after resurfacing the head).
I'm very new to the Saturn models, and its internals. I also own a Honda Civic (I know WAY more about Hondas).
ANY INFO IS HELPFUL!! THANKS!
Low Saturn Sep 20, 2007 06:28 PM
Sounds like the "mechanic" is feeding you a line. Cracked cylinder wall? Not likely. Cracked block? Only if it was run completly out of oil. Then there would be a gaping hole on one side of the block. Cracked head? Unlikely with a DOHC, since you say its a SL2. Now if it were a SL or SL1 with a SOHC, then I could believe that.
SL2510 Sep 20, 2007 06:37 PM
Well the previous owner said that the water pump was broken(or leaking I forgot) and that could have cause the cylinder to overheat and crack (if they didnt know it was broken) am I right?
From what the previous owner said (and the mechanic) that it was leaking oil. Could it be a mixture of leaking oil, and not having a water pump to crack the wall of the cylinder?
Low Saturn Sep 20, 2007 06:45 PM
I would think a blown headgasket first.
SL2510 Sep 20, 2007 06:50 PM
Ok I'll check it out.
But lets say it is the block.
Is there any other model(s) that I can get a block from and will it be direct fit?
Worste case scenario that is lol
SL2510 Sep 20, 2007 06:58 PM
(Edit)
Its a 98 sl2, Twin Cam. I'll put up a picture of the engine. Might help a bit
01dbsc2 Sep 20, 2007 08:19 PM
i belive any block from 92-98 will work.
Low Saturn Sep 20, 2007 09:26 PM
1993-2002
It would be easier to drop in an entire assembled engine though. Prices vary depending on your location.
SL2510 Sep 20, 2007 10:02 PM
Heres a pic of the engine. Hope that helps
https://i223.photobucket.com/albums/...wsolTSC/tc.jpg
01dbsc2 Sep 21, 2007 07:33 AM
1993-2002
thanks i thought it was something like that. i wasnt sure.
