my idle's too rough
Old May 6, 2009 | 07:55 PM
saturndriver's Avatar
Default my idle's too rough
on my 1997 saturn sc2 1.9l engine is idleing too rough and somewhat shaking the car which item should i be checking first? where is a good starting point?
Old May 6, 2009 | 09:24 PM
Personally, I'd start with the motor mounts on the passenger side of the car.
Old May 6, 2009 | 10:05 PM
indeed torque axis mounts (top first, then bottom)
Old May 7, 2009 | 10:41 AM
Just for the record .... the torque axis mount is the top engine mount and it will shake your teeth out if left long enough
passenger side of the engine on top.
Old May 7, 2009 | 08:59 PM
ya i checked the passenger side engine mount and its cracked but my idle is around 850 to 900 rpms is that good or bad cause my car sat for a year and a half and i think i need to clean out the IAC (idle air control) cause i think thats dirty and the o ring is bad but ill do that and keep ya posted thanks fellas
Old May 7, 2009 | 09:36 PM
Idle is not bad - especially if an auto vehicle measured in neutral or park ....
Old May 7, 2009 | 10:25 PM
as long as it is stable it is fine
Old May 10, 2009 | 09:22 PM
my car is going to be set up im going to clean the iac wensday cause i dont have work but its slowly getting better maybe the iac is cleaning itself idk
Bobbed06
Feb 22, 2012 10:41 AM
firefighter
Nov 8, 2007 04:27 PM
leftys4js
Oct 22, 2007 09:38 PM
Slick2005
Engine & Internal
Nov 2, 2005 01:02 AM
Amwreck1
Sep 26, 2005 01:03 PM
