Intermittent problem with 97 saturn
Old Jan 25, 2006 | 09:40 PM
kz10006's Avatar
Intermittent problem with 97 sl2 it will run find for some times days some times a few min and then it just dies, It will not start the check engine light does not come on. All of the electronics work it just will not start, is this the computer is craping out. Any info would be great. Thanks for your time
Brian
Old Mar 7, 2006 | 05:19 PM
anthony1987's Avatar
Might be my friend had that problem with his but id ont think its the computer on yours i believe its a sensor under the hood for you starting system or something ill find out i fixed my friends like a long timeago and im not sure what the piece was but ill find out the exact answer for you in a bit
Anthony
Old Mar 7, 2006 | 06:34 PM
kz10006's Avatar
Thank you very much for your help I did more research and I think its
the crank position sensor or the knock sensor. Thanks for
checking any help is apreciated. Have a good one
Brian
borias
Apr 5, 2011 07:19 PM
Chags
Sep 28, 2009 11:15 PM
ausemma2
Feb 19, 2009 08:05 PM
bobz5
Mar 25, 2008 07:29 PM
prawlings1
Aug 5, 2007 02:33 PM
