Intermittent problem with 97 sl2 it will run find for some times days some times a few min and then it just dies, It will not start the check engine light does not come on. All of the electronics work it just will not start, is this the computer is craping out. Any info would be great. Thanks for your time Brian |
Might be my friend had that problem with his but id ont think its the computer on yours i believe its a sensor under the hood for you starting system or something ill find out i fixed my friends like a long timeago and im not sure what the piece was but ill find out the exact answer for you in a bit Anthony |
Thank you very much for your help I did more research and I think its
the crank position sensor or the knock sensor. Thanks for checking any help is apreciated. Have a good one Brian |
