head
Old Jun 8, 2007 | 12:58 AM
mullet4's Avatar
just replaced head on 97 dohc...
followed timing chain procedure according to "tech" manual at library.
now runs but i have to feather the gas to get it to run.
no codes coming up, can't see any manifold leaks.
does anyone have any info on setting up the timing chain??
Old Jul 19, 2007 | 02:01 PM
burnout85029's Avatar
remove the top guide, unlock the timing chain tensioner, remove the chain. lock the cam gears via the hole by the bolt, now the dimples on the cam gears should be at the top. rotate the crank until the timing marks are aligned. replace the chain with the gold links on top of both the dimples on the cam gears and one on the bottom of the crank gear. replace the top guide and tighten the tensioner and lock it into place.
kia 48
Engine & Internal
Jul 7, 2008 09:11 AM
jonni 95 SL2
Sep 13, 2005 04:18 PM
youngrudy1
Jul 5, 2005 01:33 PM
betinaq
Jun 13, 2005 10:19 AM
jonni 95 SL2
Mar 18, 2005 05:17 AM
