just replaced head on 97 dohc... followed timing chain procedure according to "tech" manual at library. now runs but i have to feather the gas to get it to run. no codes coming up, can't see any manifold leaks. does anyone have any info on setting up the timing chain?? |
remove the top guide, unlock the timing chain tensioner, remove the chain. lock the cam gears via the hole by the bolt, now the dimples on the cam gears should be at the top. rotate the crank until the timing marks are aligned. replace the chain with the gold links on top of both the dimples on the cam gears and one on the bottom of the crank gear. replace the top guide and tighten the tensioner and lock it into place. |
