crank gears
Old Sep 12, 2016 | 08:47 PM
quadcoupe's Avatar
Default crank gears
has anyone replaced the drive gears on the crankshaft which the outer one turns the timing chain and the inner one turns the water pump chain I stripped the teeth on the water pump one and can't get it off
Old Sep 12, 2016 | 11:34 PM
It will pull off, you may have to use a puller. I have an outer gear stuck on a junk crank but the key has been bent by the crank pulley. If your water pump did not seize check your balance shafts closely, you may have a bad bearing deep in the block.
Old Sep 13, 2016 | 08:31 AM
quadcoupe's Avatar
that was what I thought but no luck yet,maybe I needed a fresh day for it to look better but anyway thanks
Old Sep 16, 2016 | 10:42 PM
quadcoupe's Avatar
still no luck so I took a torch to the gear and made a big mess of it,took all parts off and replaced both gears and that gizmo thing that keeps tension on the timing chain. Everything else turned smoothly and very easy so maybe I was lucky,time will tell but right now this thing is quieter than it has been in a long time and I will watch it closely for problems.
Old Sep 16, 2016 | 11:20 PM
They are very quiet when the chains are good. Glad you got it back together.
Old Sep 17, 2016 | 06:00 PM
Congrats on the fix. Now how about a photo of that 68 Dart?
Old Sep 20, 2016 | 11:55 PM
quadcoupe's Avatar
I myself cannot believe I do not have a good picture of the 69 Dart that I drove for 29 years and 270k miles only a picture of the broken beast when I first bought it
Old Sep 21, 2016 | 12:02 AM
Bad pic is better than none at all......
SaturnJeff
Jan 15, 2010 07:10 PM
ziddey
Jun 7, 2009 02:07 PM
Bmick68
Jan 18, 2009 10:14 PM
Deli Dave
Sep 27, 2008 10:44 PM
jeffwallner
Aug 3, 2008 07:07 PM
