Front Speakers
I want to replace the front speakers of my '99 SC2
I tried to take the panel off but failed.
For the drivers side door theres a screw on the left, then the 2 door handle screws. And one near the bottom. And thats as far as I can get. I don't want to crack the panel. Can anyone tell me how to take it off.
Unscrew the piece that holds the handle in. Unclip handle and lock from the bars in the door. Unscrew the remaining screws. There aresix or seven clips that lift up and out. So gently grab the door panel by the bottom and the hole where the handle was (that's how I did it) and lift up about half to one inch. Then pull out. If anything snags, make sure every part lifted. I had trouble with the bottom clip that's farthest away from the hinge.
earlschieb
Aug 4, 2009 10:51 AM
