Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification... let's hear about it here...
98 SL Stero Help
Old Nov 27, 2008 | 01:39 PM
rameans23's Avatar
ok so i have a 98 sl and it has just the regular tape player in it i wired up a jvc head unit just basic cd player.....i cant seem to get power to it???? I can have it plugged in and nothing then i can unplug it and plug in the stock one and it works? All the fuses are good so i need some help i have installed many stereos and never had this problem
thanks guys
Old Nov 27, 2008 | 02:55 PM
Low Saturn's Avatar
Did you wire the radio harness adaptor correctly? Is the fuse on the JVC blown? Have you verified the the JVC is functional?
Old Nov 27, 2008 | 03:15 PM
rameans23's Avatar
yea its wired correctly and the fuse and the head unit both are brand new right out of the box
Old Nov 27, 2008 | 03:27 PM
Low Saturn's Avatar
But does it work? Its possible that you got a bad unit. I''d start by verifying that the unit actually works and work from there.
Old Nov 27, 2008 | 04:13 PM
rameans23's Avatar
could i hook it up to say a 9 volt battery to check?
Old Nov 27, 2008 | 04:50 PM
Sounds like the JVC has a different pin-out on the plug than the OEM unit. And, you need a 12 volt battery to test with ...
Old Nov 27, 2008 | 10:15 PM
Low Saturn's Avatar
The one under the hood of the car would work better.
Shadowman750
Mar 28, 2008 10:50 AM
CoastGuardGuy
Jun 27, 2006 01:25 AM
