Rough idol
Old Aug 14, 2006 | 12:42 PM
citro's Avatar
HI
I have a 1997 SW2 automatic, 114000 miles. The car has a rough idol when I am stopped with transmission in drive. It runs smooth in Park and netrual. It uses no oil and the plugs are a nice tan color, the gas milage is great. I have changed the plugs, air, fuel and tranmission filters.The transmisssion has no slippage. Does any one know if there is some kind of sensor that would effect the idol when it is in drive?It seems to get worse with cold weather.
thanks
citro
Old Aug 15, 2006 | 12:10 AM
Is it a rough idle or a vibration that comes through at the lower rpms in drive (at idle with foot on the brake)?
You are probably overdue for a torque axis (upper engine) mount. These usually go about every 70-100K mi and tend to transmit excessive vibration through to the passenger compartment.
If it is truly running rough, I would suggest a throttle body cleaning.
And consider changing the ECTS (Engine Coolant temp sensor), especially if the original is still in there. Replace with brass Saturn replacement. Replace the connector as well (Saturn only part).
Bobbed06
Feb 22, 2012 10:41 AM
eliot
Sep 27, 2007 08:13 AM
angora6
Apr 15, 2007 06:05 PM
Slick2005
Nov 2, 2005 01:02 AM
Amwreck1
Sep 26, 2005 01:03 PM
