Suspension Talk about your suspension within...
strangeness Monroe strut replacement on 97 SC2
Old May 1, 2010 | 04:35 PM
Default strangeness Monroe strut replacement on 97 SC2
Hey,
Anyone replace their S car stock struts with Monroe Sensatrac's?
I purchased the 71924 STs for the front and the 71925 ST's for the back
The back 71925 ST's went fine.
The front Monroes 71924 seem to have an overall shorter piston travel (distance from top of piston to lip for bottom of spring).
Consequently, in order to reinstall the mounting plate (with bearing) and the rubber bearing support that goes between the mounting plate and the top of the spring, I had to further compress the spring.
The result (as the laws of physics tell me) is that the spring is now under more static tension since it is under additional compression not there under stock conditions.
The result is a bunch of clunking (presumably because the strut can't compress due to the spring compression) and squealing from the top of the strut tower, which I assume is due to the bearing being under so much tension that it can't move and the rubber support is actually moving instead.
Anyone else had this problem?
Old May 1, 2010 | 05:03 PM
MONROE struts .... I've yet to buy a set
spring compressor
Old May 2, 2010 | 03:06 PM
I don't use Monroe either (personal choice).......
Old May 2, 2010 | 07:36 PM
I stumbled upon a Monroe spec manual with lengths of everything so I will pull them out, likely find they do not meet spec and are likely stamped with the right part number but are NOT the right part.
Then I'll order some KYBs like I did for my 95. I was trying to get a smoother ride in the 97 vs the 95 -- all I got was a bunch of sheeeet apparently
Old May 5, 2010 | 04:01 PM
OK,
Replaced fronts with KYB GR-2's and except for a bit of spring rubber squeal on the front right (I'm using the monroe mounts with the bearings since I already bought them) things are fine. Ride is fine-- not the jarring crap with the monroes.
Yes, I made sure to reassemble with the rubber in the exact same location it was on the spring when I pulled it.
No I did not over torque the top mounts.
Any ideas?
Any one want a set of Monroe struts---suitable for most any couterweight or large-object slingshot application?
jcoyle
Jun 3, 2009 03:39 PM
anti-rice 01sl2
Suspension
Apr 8, 2008 10:08 PM
B_MaTh
Nov 16, 2007 09:29 AM
furby
Mar 5, 2007 02:46 PM
mjdjlh2000
Jun 15, 2005 02:57 PM
