Saturn Ion problem
Old Oct 4, 2009 | 12:42 PM
HPR's Avatar
HPR
Question Saturn Ion problem
I have a Saturn 2004 Ion that moves without stepping on the gas.
It idles at 700rpm in park but does not drop when shifted into any gear. It will even go uphill in gear without pressing the gas pedal. I took it to Saturn and they replaced the Idle Air Control Valve but it still has the problem. They also reprogramed the PCM per bulletin 04-06-04-029A....HELP
Old Oct 4, 2009 | 05:50 PM
HPR
Junior Member Join Date: Oct 2009
Saturn Ion problem
"I have a Saturn 2004 Ion that moves without stepping on the gas.
It idles at 700rpm in park but does not drop when shifted into any gear. It will even go uphill in gear without pressing the gas pedal. I took it to Saturn and they replaced the Idle Air Control Valve but it still has the problem. They also reprogramed the PCM per bulletin 04-06-04-029A....HELP"
At what rpm would you like to see it idle at when in drive? 700 RPM in drive sounds a bit low to me.
Old Oct 4, 2009 | 06:01 PM
Sounds like pure bullchit to me.
Old Oct 4, 2009 | 06:14 PM
700 RPM seems like a reasonable idle speed when in gear. If you have a problem with the car going without stepping on the gas - try stepping on the brake, it should work
Old Oct 4, 2009 | 06:19 PM
The brake ........... he never thought of that.
Old Oct 5, 2009 | 05:00 PM
Sounds like something lowsaturn should handle ..... ya think?
Old Oct 5, 2009 | 08:13 PM
lowsaturn lowsaturn whereforartthou lowsaturn?
Maybe its a turbonator issue....I thought the turbonators on the Ions were pretty solid but i guess anything's possible
Old Oct 17, 2009 | 10:17 PM
I should delete this thread but everyone must see how some people are to stupid to drive etc.
bartelbjones
Nov 22, 2020 02:11 AM
buzzchamp33
Oct 31, 2014 11:54 PM
mike82
Jul 12, 2011 09:01 AM
ptgee
Sep 20, 2009 09:47 PM
RjION
Sights N Sounds
Mar 14, 2009 08:10 PM
