2001 L300 Speedometer
Old Sep 2, 2009 | 12:31 PM
obie36's Avatar
Default 2001 L300 Speedometer
My car wouldn't start (or take a jump) the other day. I had the battery checked and it had a full charge but failed the load test. Replaced the battery and now the speedometer stays at zero and the trip odometer reads zero. Funny thing is that the cruise control still works. Any idea what could be wrong?
Old Sep 3, 2009 | 04:02 PM
++++++++The engi+ne +oes not start but the CC works ........ thats pretty cool. You can cruise down the road with the engine not running. You'll save a bunch in gas.
Old Sep 3, 2009 | 09:13 PM
ffffffffffuses?
Old Sep 14, 2009 | 09:28 PM
rlembitz's Avatar
i have the exact same problem with my car... see if your ac is working, cause my bcm (body control module) went out on me and not my ac doesnt work (happened to my fellow l300 friend too) and the whole instrument cluster will only work for a fraction of a second right after the key is inserted then wont work the rest of the drive.
Old Sep 19, 2009 | 10:12 PM
Fuses would be the place to start, then check for loose ground straps/wires
cherokee9
13
Jul 31, 2019 07:05 AM
fiddlebick
Jan 24, 2009 08:11 PM
Alwaysfishin'
May 28, 2008 12:47 PM
PhantomLover007
May 23, 2007 08:41 PM
Gordon Bowden
Dec 20, 2006 10:36 PM
