Losing Gas Mileage?????
Old Oct 4, 2005 | 02:39 AM
HeatherP00's Avatar
I normally run about 400 mile to a tank of gas, I have a AT 01 SC2 with 35,000. Just recently i've lost gas mileage, I now get about 200 to a tank. My car also is idling at 2000 every once in awhile.. What can be wrong?
Old Oct 6, 2005 | 04:22 AM
desperado's Avatar
i think i posted my reply on a different forum..[img]smileys/smiley2.gif[/img]
Old Oct 7, 2005 | 04:19 AM
Crispy983's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Alot of things. your car could be getting the wrong mixture of air and gas. have you gave it a tune up? =oil, oil filter, sparkplugs, wires ect ect. It could be the idle speed got messed up, which is an easy adjustment on older cars any way. Also i went from 350 miles down to about 200. Then I took a trip by plane came back tripometer said 149 and i had half a tank. burned the rest of the gas filled it up went to reset the tripometer and it was still at 149, now whenever i reset it it doesn't go past 9/10 of a mile. so bump your miliage with your odometer also.
Old Oct 10, 2005 | 12:37 AM
HeatherP00's Avatar
I think I figured it out, I found a small crack in the intake tube, and my plugs were gapped at .050 so I put them to .040 and fixed the crack. I'll let you know if it works..
Old Oct 10, 2005 | 12:51 AM
Crispy983's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
if(SymReal != null)
SymReal();
SymOnLoad()
SymRealOnLoad();
SymReal = window.;
window. = Sym;
when was the last time you changed your airfilter that has ALOT to do with gas milage
tylerrf911
Jan 28, 2009 09:17 PM
armedgentleman
Jun 12, 2008 09:44 AM
imaukfan
Jun 10, 2008 06:34 AM
Playincard
Sep 5, 2007 12:55 AM
HeatherP00
Oct 10, 2005 12:21 AM
