I normally run about 400 mile to a tank of gas, I have a AT 01 SC2 with 35,000. Just recently i've lost gas mileage, I now get about 200 to a tank. My car also is idling at 2000 every once in awhile.. What can be wrong?
i think i posted my reply on a different forum..[img]smileys/smiley2.gif[/img]
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> Alot of things. your car could be getting the wrong mixture of air and gas. have you gave it a tune up? =oil, oil filter, sparkplugs, wires ect ect. It could be the idle speed got messed up, which is an easy adjustment on older cars any way. Also i went from 350 miles down to about 200. Then I took a trip by plane came back tripometer said 149 and i had half a tank. burned the rest of the gas filled it up went to reset the tripometer and it was still at 149, now whenever i reset it it doesn't go past 9/10 of a mile. so bump your miliage with your odometer also. |
I think I figured it out, I found a small crack in the intake tube, and my plugs were gapped at .050 so I put them to .040 and fixed the crack. I'll let you know if it works..
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> when was the last time you changed your airfilter that has ALOT to do with gas milage |
