99 sl2 stuck ignition key
Old 04-15-2010, 12:03 PM
miami man's Avatar
Default 99 sl2 stuck ignition key
i have a key stuck in the ignition and cannot get it out. someone said that the keys are codded ect and getting a lock and key from the junkyard will not help and just go to the dealer to get a new ignition lock and key made.
is this true or what are the other options for me besides going to the dealer/
thany you for your help
Old 04-16-2010, 12:03 PM
hoseppi's Avatar
If the switch is in the acc. position, you can remove the plastic cover and then remove the whole cylinder with the key. With the cylinder out, you should be able to remove the key. Get a new one cut from the VIN and see if that fixes the problem.
Old 04-19-2010, 09:08 AM
miami man's Avatar
well i found a lock and key in the junkyard and put it in and it works but will it keep working meaning not matched up to the vin#
Old 04-19-2010, 02:00 PM
You should be ok ...............
Old 04-20-2010, 09:13 AM
miami man's Avatar
i was working on the old lock on my desk at work now old assembly works...go figure.
Old 04-20-2010, 11:12 AM
Go figure
greygoose08
01-10-2014 05:52 PM
stemiched89
01-11-2012 09:53 AM
Steffie575
08-21-2010 01:34 PM
Brumac
02-23-2010 10:15 AM
saintfn1
12-12-2005 07:04 PM
Quick Reply: 99 sl2 stuck ignition key
