2001-2002 SL2 whining noise front drivers side
Old Jan 15, 2022 | 08:14 PM
Abonney's Avatar
Default 2001-2002 SL2 whining noise front drivers side
I have an odd whining noise coming from the front drivers side up until I hit 3rd-4th gear. It doesn’t do it in neutral or park. It isn’t affecting acceleration or braking any.
Old Jan 16, 2022 | 07:27 AM
Have you ever changed the transmission fluid and filter? Maybe the filter is sucking air.
Old Jan 16, 2022 | 04:47 PM
Does it track with miles per hour or RPM? Like if you take your foot off the gas, does the pitch of the whine track with the RPMs dropping.? Also, what happens if you are moving along at a speed where you are hearing this whining and you put it into neutral? Does the sound stay or go. I know you said it doesn't do it in neutral but I'm assuming that was while you were parked or shall I say not moving
ASMobile
Jan 18, 2014 08:48 AM
Racingchick
Oct 16, 2010 10:05 AM
axe05
Apr 23, 2010 12:49 AM
tubbsey88
Jul 7, 2008 11:20 AM
latestgood
May 5, 2008 09:20 AM
