Timing belt replacement
Old Mar 21, 2014 | 05:31 AM
kzdcz3's Avatar
Default Timing belt replacement
It's time to replace the timing belt in 2004 Vue with Honda 3.5 V6. Is there any good brand that I should buy? My car does not leak oil, should I replace the cam/crank seals? Thanks,
Old Mar 21, 2014 | 07:32 AM
I don't know the replacement recommendation, but if you do it, you'd better replace the water pump too. It's driven by the timing belt and you don't want to have to go back an do stuff over again. Just replace all of the stuff while you're in there and be done with it. I THINK it's around 100,000 t0 105,000 miles.
Racemare
Jan 9, 2008 09:43 PM
90base
Sep 27, 2007 04:05 PM
shakr
Sep 6, 2007 11:35 PM
vetteguy
Aug 20, 2006 09:26 AM
B3SL1
Aug 4, 2005 09:49 AM
