Replacement Transmission Pan 2008 Vue 2.4L
Curious to know if anyone has used the Dorman 265809 replacement pan with drain plug?
Satisfied? I've read replacement gasket required; supplied gasket leaks.
Gasket part # and torque that works?
Appreciate any feedback.
Thanks,
Thanks,
Follow-up: Installed the Dorman 265809 replacement transmission pan with drain plug. Based on reviews, I replaced the crush washer with a Dorman aluminum / rubber gasket 095-156CD.
Torqued to 18 ft-lb. Only 1 day of use, but looks good.
