Replacement Transmission Pan 2008 Vue 2.4L
Old Jan 25, 2026 | 06:21 PM
TXSaturn's Avatar
Default Replacement Transmission Pan 2008 Vue 2.4L
Curious to know if anyone has used the Dorman 265809 replacement pan with drain plug?
Satisfied? I've read replacement gasket required; supplied gasket leaks.
Gasket part # and torque that works?
Appreciate any feedback.
Thanks,
Old Jan 26, 2026 | 07:38 PM
grcauto8453's Avatar
We used to install a drain on the pan of many models.
Old Feb 2, 2026 | 05:21 PM
TXSaturn's Avatar
Follow-up: Installed the Dorman 265809 replacement transmission pan with drain plug. Based on reviews, I replaced the crush washer with a Dorman aluminum / rubber gasket 095-156CD.
Torqued to 18 ft-lb. Only 1 day of use, but looks good.
Old Feb 2, 2026 | 07:20 PM
Thank you for the followup!
Bunjamin
Oct 11, 2022 10:00 PM
New07Vue2.2
Jun 3, 2021 10:02 AM
JBNJ
Oct 22, 2009 07:14 AM
HeySteve1989
Aug 28, 2008 10:04 PM
portum89
Oct 25, 2007 08:15 AM
