-   -   Intermitent CKP error (https://www.saturnforum.com/forum/saturn-vue-24/intermitent-ckp-error-13765/)
pic_az May 11, 2025 12:08 PM
I got a code for the CKP about 2 months ago and replaced it and did a relearn with my scanner. I now get every couple of weeks the code again. Sorry, I just cleared it this morning and forgot to write it down. It appears to only happen during a start of the engine. Every once in awhile it will code as an engine misfire. Both of these clear themselves after a few more starts. The next time it codes, I will have the code. It's more annoying than anything else as I am thinking it could be something more serious so I have to check it. The last codes have been only those 2. I know I should have the code for you but I thought I would throw this out and see if anyonre has any ideas.
Joey
pic_az May 11, 2025 12:11 PM
I forgot to mention this is a 2006 Saturn Vue 2.2L.
grcauto8453 May 11, 2025 03:44 PM
Get us the code.
pic_az May 13, 2025 12:51 PM
Looks like I jumped to quickly. The code is P0340. It is the Camshaft sensor and not the Crankshaft sensor. I will order one and replace.
pic_az May 13, 2025 01:01 PM
Back again. From what I am seeing, there is no Cam Position Sensor and they are using the ECM. Is that correct? I replaced the whole Coil Pack and ECM about 3 months ago. Yes, kind of when all this began, If the location is true, I am wondering if the ECM is bad. Any thoughts?
pic_az May 13, 2025 01:03 PM
Looks like I jumped to quickly. The code is P0340. It is the Camshaft sensor and not the Crankshaft sensor. It appears from what I am seeing that there is no Cam Position Sensor per se. It looks like they are using a connector on the ECM. I replaced the whole coil pack and ECM about 3 months ago. Now I am wondering if the ECM is bad.
ANy thoughts?
pic_az May 13, 2025 01:25 PM
I'm sorry, I said ECM but meant Ignition Control Module.
derf May 13, 2025 04:14 PM
What plugs do you have in there?
pic_az May 13, 2025 04:32 PM
I changed those plugs around 80K and now have 103K. I think they are NGK but I am not positive. I just replaced the ICM with my old one and the code cleared itself. I turned in the new one for a warranty replacement as it had 12 month warranty.
Rubehayseed May 13, 2025 05:06 PM
Usually when problems show up after replacing old parts with new ones, one of the new parts is the issue. If you're buying crap from Autozone or Advance, STOP. I have worked for both in the past and most of the stuff they sell is substandard quality. I don't shop at either one unless I see a sale on Techron products. I try to buy online and if rockauto or the manufacturer is out of it, I'll try NAPA. O'Reilly is next to last with the other two mentioned as LAST RESORTS.
