Battery Light on Gauge Cluser
Old Feb 9, 2009 | 07:48 PM
ion87-87's Avatar
The battery icon is coming on when I start the truck up in the morning when it is cold outside. I am wondering if this is only because it is cold outside and the battery needs a little time to charge up? Any info on this would help.
Old Feb 9, 2009 | 09:13 PM
Excuse my stupidity, but I was not aware Saturn built a truck ...
Old Feb 10, 2009 | 07:18 AM
ion87-87's Avatar
sorry it is a SUV. but i have a tendency of calling it a truck.
Old Feb 10, 2009 | 07:37 AM
Well, a start on very cold mornings will take a lot out of a battery, and if the battery is more than three years old, it might be having problems maintaining a full charge. However, if the serpentine belt is worn, it could slip enough to where the alternator is not spinning at full speed. If that happens, you could get your light. A third possibility is that the alternator itself may be weak. Go to AutoZone (O rileys, Pepboys, or similar) and have them run a test on your charging system ...
Old Feb 11, 2009 | 08:07 AM
04vue's Avatar
I''m having the same issue, they ran a check on the battery and they said it was in good shape. This morning was 36 degrees and it came on and stayed on for about 3 minutes then it went off.
My husband unplugged the battery last night with the vue running and it stayed running, so we kind of figured out that it wasn''t the alternator.
I will try the autozone approach tonight after work, otherwise I have no clue what could be going on.
cardhuu
May 12, 2023 08:30 PM
jeffandsonia
May 19, 2011 08:19 AM
helistructor
Aug 12, 2010 10:46 PM
bills
Feb 15, 2009 03:01 PM
FeMerican
Jul 11, 2008 10:49 AM
