Air bag
Click around. The entire manual is here.
Home >> Saturn Truck >> 2007 >> VUE FWD V6-3.5L >> Repair and Diagnosis >> Restraints and Safety Systems >> Repairs and Inspections Required After a Collision >> Service and Repair >> Supplemental Inflatable Restraints
Accident With or Without Inflator Module Deployment - Component Inspections
Caution: Proper operation of the SIR sensing system requires that any repairs to the vehicle structure return the vehicle structure to the original production configuration. Not properly repairing the vehicle structure could cause non-deployment in a collision or deployment for conditions less severe than intended.
After any collision, inspect the following components as indicated. If you detect any damage, replace the component. If you detect any damage to the mounting points or mounting hardware, repair or replace the mounting points and mounting hardware as needed.
* The steering column-Perform the steering column accident damage checking procedures. Refer to Steering Column Accident Damage Inspection. Steering Column
* The instrument panel (I/P) knee bolsters and mounting points-Inspect the knee bolsters for bending, twisting, buckling, or any other type of damage.
* The I/P brackets, braces, etc.-Inspect for bending, twisting, buckling, or any other type of damage.
* The seat belts-Perform the seat belt operational and functional checks. Refer to Operational and Functional Checks. Operational and Functional Checks
* The I/P mounting points and brackets-Inspect for bending, twisting, buckling, or any other type of damage.
* The roof rail and roof rail module mounting points-Inspect for bending, twisting, buckling, or any other type of damage.
* The seats and seat mounting points-Inspect for bending, twisting, buckling, or any other type of damage.
* Passenger seat bottom equipped with Passenger Presence System (PPS) - Check for any DTCs or problems that may cause the PPS to not function properly.
Accident With Frontal Air Bag Deployment - Component Replacement and Inspections
After a collision involving air bag deployment, replace the following components. If you detect any damage, replace the component. If you detect any damage to the mounting points or mounting hardware, repair or replace the mounting points and mounting hardware as needed.
Important: The front passenger seat is equipped with a PPS, which detects an occupant. If the requirements for disabling the I/P air bag are met, then the PPS will communicate with the SDM to disable/turn off the I/P air bag, even in an accident. For more information on the PPS refer to SIR System Description and Operation.
* Inflatable restraint I/P module, if deployed and after performing the necessary inspections listed above.
* Inflatable restraint sensing and diagnostic module (SDM)
* Inflatable restraint steering wheel module
* Inflatable restraint steering wheel module coil
* Seat belt pretensioners
Perform additional inspections on the following components:
* Steering wheel module coil and the coil wiring pigtail-Inspect for melting, scorching, or other damage due to excessive heat.
* Mounting points or mounting hardware for the I/P module, steering wheel module, SDM, seat belt pretensioners, and vehicle rollover sensor-Inspect for any damage and repair or replace each component as needed.
* Passenger presence system (PPS) for damage to the wiring or pressure system
Accident With Side Air Bag Deployment - Component Replacement and Inspections
After a collision involving side air bag deployment, replace the following components:
* Inflatable restraint roof rail module, on the side of the impact.
* Inflatable restraint side impact sensors (SIS) (left/right), on the side of the impact
* Inflatable restraint roof rail module (left/right), on the side of the impact
* Inflatable restraint SDM
* Seat belt pretensioner, on the side of impact.
* Mounting points or mounting hardware for the SIS, roof rail module (left/right), and seat belt pretensioner on the side of impact-Inspect for any damage and repair or replace each component as needed.
* Mounting points or mounting hardware for the SDM and vehicle rollover sensor-Inspect for any damage and repair or replace each component as needed.
Sensor Replacement Guidelines
The SIR/side air bag sensor replacement policy requires replacing sensors in the area of accident damage. The area of accident damage is defined as the portion of the vehicle which is crushed, bent, or damaged due to a collision. An example of this would be a moderate collision where the front of the vehicle impacts a tree, if the vehicle has an SIR sensor mounted forward of the radiator, replace the SIR sensor.
* Replace the sensor whether or not the air bags have deployed.
* Replace the sensor even if the sensor appears to be undamaged.
Sensor damage which is not visible, such as slight bending of the mounting bracket or cuts in the wire insulation, can cause improper operation of the SIR/side air bag sensing system. Do not try to determine whether the sensor is undamaged. Replace the sensor. Also, if you follow a diagnostic trouble code (DTC) table and a malfunctioning sensor is indicated, replace the sensor.
