2008 Vue XE: CV Axle question
Old Apr 20, 2025 | 04:24 PM
moreno7798's Avatar
Default 2008 Vue XE: CV Axle question
Recently I changed the front CV Axles in my 08 Saturn Vue. I could not find AC Delco Axles so I went with the Cardone brand. When I pulled the original and compared it to the Cardone, I noticed that the original was about 2 inches longer than the new one. I was careful when I bought it to match it to my exact model and trim. I have already installed the Axles and they appear to work fine but I was wondering if that is going to cause some problems later. Do the CV axles have some length range that could allow it to use a bit shorter Axles?
Old Apr 21, 2025 | 03:11 PM
grcauto8453's Avatar
2 inches longer I'm surprised you were able to install it.
Old Apr 23, 2025 | 07:37 PM
moreno7798's Avatar
Yeah. I felt unconfortable installing it. Right now the steering wheel is not returning to center quickly when making a turn. But this may be an alignment issue. I'm waiting to get my alignment done first, then see how the car feels when turning to see if I should get reman OEM instead. BTW, this is the part I bought. Website says it is a fit, but when comapred it was shorter.
https://www.carid.com/2008-saturn-vu...139957328.html
Old Apr 24, 2025 | 12:12 AM
I think I'm confused. I thought your earlier post stated The replacements were 2 in longer, not shorter. Please advise
Old Apr 24, 2025 | 08:54 AM
Is your car a V-6 or a 4 cylinder? I don't know if it makes any difference, but it MIGHT. IDK, I'm not a mechanic.
Old Apr 24, 2025 | 02:21 PM
Shorter...longer....whatever it is it's not the correct axle.
Old Apr 24, 2025 | 02:32 PM
moreno7798's Avatar
The new ones from Cardone are shorter. The original Axles were longer. I don't know how much longer exactly, but they were longer. I already got rid of them now so I can't give an exact measurement. I also thought that maybe the originals were longer from being uncompressed (in an extended state) in the car for so long. I might be wrong.
Old Apr 24, 2025 | 02:48 PM
moreno7798's Avatar
It's 4 Cylinder.
It's kind of strange. Another weird thing - When I bought new inner tie rod ends (I tried different stores), for some reason the inner threads were different (wider) than the original tie rods-even though they were matching the part to my specific car. No matter where I went (O'reilly, Advanced Auto Parts...), the part they matched to my car had the wider inner threads. I ended up having to get a complete remanufactured steering rack assambly with the inner tie rods already attached. Replaced the whole thing.
Old Apr 25, 2025 | 09:09 AM
Was there some kind of mid year changeover on the Vue? Maybe try going up or down a year to see if parts come up as the same # for your 08. Once again, I don't know and am frankly just too lazy to check them for you.
Old Apr 25, 2025 | 01:42 PM
moreno7798's Avatar
It's possible. Usually when I match the part Online, it's the same part for several different Model/Brand years. I have a feeling they might have made suttle changes after the brand was killed and then discontinued the original early parts. I could be wrong though. I'm gonna post a pic of the original and new parts when I have a chance.
