-   -   2007 Vue Hybrid Starting issue (https://www.saturnforum.com/forum/saturn-vue-24/2007-vue-hybrid-starting-issue-11577/)
Bloom Blooms Jan 19, 2019 07:47 AM
Battery takes charge however the ignition acts totally dead. All lights work but it just wont turn. Then all the sudden, poor! Fires like there is no issue.
is there a solenoid or fuse I need to look into changing or is it the starter itself?
ps- I cannot find owners manual. I'm frustrated so hoping someone may have the answer. Thanks!
Rubehayseed Jan 19, 2019 08:03 AM
First thing to do is remove both battery cables and clean the clamps and the posts. I suspect you have a corrosion problem. And if you keep having to get the battery charged, it probably needs replacing. Take it to your local auto parts store and have it LOAD TESTED.
