2007 Vue Hybrid Starting issue
Battery takes charge however the ignition acts totally dead. All lights work but it just wont turn. Then all the sudden, poor! Fires like there is no issue.
is there a solenoid or fuse I need to look into changing or is it the starter itself?
ps- I cannot find owners manual. I'm frustrated so hoping someone may have the answer. Thanks!
First thing to do is remove both battery cables and clean the clamps and the posts. I suspect you have a corrosion problem. And if you keep having to get the battery charged, it probably needs replacing. Take it to your local auto parts store and have it LOAD TESTED.
