2004 Saturn Vue V6 3.5l AWD
Hello everyone my name Jessii and I'm new here...I'm having an issue with my 2004 Saturn Vue V6 3.5l AWD with it not wanting to start at all 🤦♀️🤦♀️ There's absolutely NO crank Or start what so ever and it's been down for a month..There's full power to the dashboard lights wipers headlights etc it just won't start Or even crank over..Someone please help me!!!
Battery must be dead by now. Can you start it If you jump it from a known good battery in a running vehicle?
Did the vehicle just not start one day or did something happen that precipitated the engine no longer running followed by never being able to start it again? How many miles? |
Have you checked the battery cables for clean, tight connections? It doesn't take much corrosion to kill one. My first suspicion is simply a dirty, loose ground cable and connection.
Yes a known good, charged battery is essential.
Do the lights ( headlights or dome light) dim when you turn the key to start ? If not then I suspect something in the starter circuit. |
Originally Posted by lrbraner
(Post 64621)
Do the lights ( headlights or dome light) dim when you turn the key to start ? If not then I suspect something in the starter circuit. Have you tried to turn the motor over by hand ? |
Okay......
How about we all slow down and let this person answer at least one question? That and I am not sure how you use headlights to diagnose starter issues so let's take a step back..... |
