'06 Vue rear left door latch
I am having a problem with my door latch on the rear drivers side. Sometimes it latches and sometimes it doesn't. It is becoming a pain. I am worried that someday it will just open up.
I called the dealer and they told me there are no recalls on the problem. A new latch is 75 +tax, which I think is ridiculous.
Where do you all go to get your parts.
Do you know if there are any aftermarket parts companies that would sell a replacement?
Thanks in advance
Thanks in advance
Usually, coachwork items like door latches, etc are OEM only. Your other option, is to haunt your local wrecking yards (u-pull-it) for a hulk what matches your needs.
Are you sure the latch is truly defective, and not just mis-adjusted or mis-aligned ??
I tried to re adjust it but after removing the striker, the bolt holes are all counter sunk. So it didn't look like I was able to make any adjustment. Same with the locking mechanism.
I actuated the latch with my finger and it seemed it didn't want to "latch" all the time. I went over to the passenger side door and it feels different. The one that seems defective moves much more freely than the one that works.
Thanks in advance
Thanks in advance
LowerThanLow
Sep 3, 2009 07:59 PM
