05 Saturn Vue
Old Nov 19, 2010 | 05:30 PM
ROKO's Avatar
Default 05 Saturn Vue
Good evening, I am looking for the fuse panel inside the vehicle as my parking lights do not work. I have checked my manual and it says the panel is on the passenger side of the lower console. I cannot find where they are talking about. The only spot I can see is a triangular pull out on the cover for the dog house. This panel won't come off, I am afraid to bust it. Is this the panel cover they are talking about? Thanks ROKO
Old Nov 19, 2010 | 06:24 PM
It will be on the plastic shroud that encloses the center console, on the passenger's side, very close to where their left foot would be ......................
Old Nov 19, 2010 | 06:37 PM
Be carefull it doesn't jump out and bite you......could be painfull.
Old Nov 20, 2010 | 04:59 AM
ROKO's Avatar
Default Fuse panel
Thanks guys, I will watch my fingers! ROKO
Old Nov 20, 2010 | 05:09 AM
Watch your rings too, when working around electrical circuits. You would not believe just how hot a simple wedding band can get when your hand's caught between the fuse block and the dashboard support bracket
Old Nov 20, 2010 | 11:41 AM
ROKO's Avatar
Default Fuse panel
Problem solved, thanks guys. My trailer caused a short in car. Fixed now, thanks again.
Old Nov 20, 2010 | 12:22 PM
OK ROKO -- glad your car is fixed.
PARK fuse was probably blown due to a short in either the trailer hazard (side) lights, or the taillights themselves. Little pieces of information like (.."I hooked up my trailer, and the lights went out"..) help us pick through the problem to come up with the answer
Old Nov 23, 2010 | 07:14 AM
ROKO's Avatar
Default Fuse panel
Replacing the fuse no problem , finding the short, now that could be a problem. Roko
