-   Saturn Sky (https://www.saturnforum.com/forum/saturn-sky-33/)
-   -   Top won't close? Fix it! (https://www.saturnforum.com/forum/saturn-sky-33/top-wont-close-fix-11754/)
bbbacres Aug 18, 2019 05:18 PM
Many owners have posted about the problem of a top that will no longer close. It is because a small red clip on each side is broken. This clip is concealed but it allows you to hook on a rod that opens up the two flaps you see along the back edge of the car under the top. these flaps must be raised to close the top and if the clips are broken the flaps will not raise.
this cannot be repaired by replacing the small clips on either one side or both sides depending on what is broken
Let me save you all a lot of trouble. After looking on line at auto parts stores, in amazon, on ebay, and more, I found this simple little part at NAPA locally. It was ON THE SHELF and cost $4.00 for each side and the man was nice enough to clip them on Several of the references above are wrong. Try this, I just did it ONE hour ago. NAPA part # 735-2786. Get the right number, a number of these clips are out there and they are different sizes.
derf Aug 18, 2019 06:01 PM
Indeed. All 0 of the above references are wrong.
Thanks for the info.
Could you please add a picture of the part inside and out of the packaging and where to install it on the vehicle?
Thx
Rubehayseed Aug 19, 2019 08:05 AM
Ehhhhh, I'm confused. Which Saturn model are you referring to and is that the sunroof that you're talking about?
derf Aug 20, 2019 06:27 AM
Sky
Fold down/up top
Rubehayseed Aug 20, 2019 12:15 PM
Thanks, derf. I was wondering if I missed a vert other than the Sky. I was thinking that was some fix for the crappy sunroofs. Too bad it isn't!
