Battery tender
Old Nov 10, 2020 | 07:04 PM
Ken Barrick's Avatar
Default Battery tender
I just bought a 5v NOCO battery tender for my 2007 Sky. I had a new battery installed around July and will be storing it in my unheated attached garage in Southern Michigan. My question is, should I connect the tender directly to the battery terminals. Or should I connect to the electrical box above the battery and the negative connection attached to the engine, or doesn't it make any difference? Thank you.
Old Nov 11, 2020 | 06:33 AM
Given the small amount of current, I am not sure if it matters, but I believe best practice on the newer cars is to connect to the positive connection point not at the battery and the same for the negative connection at the frame. Many manufacturers now use electronics to control among other things battery load shedding and such. The circuitry tends to be installed right on or shall we say off of the end of the battery lead on the positive. This is why when you jump start a newer car, you are supposed to avoid direct battery connections because you are sending huge current spikes through those electronics that they were not designed to see let alone withstand.
Hopefully someone else will come along and confirm or correct the above.
Old Nov 11, 2020 | 09:09 AM
I would follow the charger instructions.
Old Nov 11, 2020 | 03:44 PM
Classic, Andy.
(Slithers into darkness)
Old Nov 11, 2020 | 04:27 PM
I have opinions but it is often safer to follow the manufacturers suggested instructions.
Old Nov 11, 2020 | 09:01 PM
I have opinions and I often share them too freely
Old Nov 11, 2020 | 09:10 PM
Touche my friend.
jamnar
Feb 10, 2019 05:53 PM
Smshm3fmf
May 27, 2016 09:53 PM
Oscar
Jun 18, 2007 07:10 PM
Rabidawise
Feb 1, 2007 01:04 AM
sirfodder
Jul 19, 2006 01:30 AM
