2008 Sky Redline battery light intermittent
Old Jul 12, 2020 | 07:30 PM
Dorice's Avatar
Default 2008 Sky Redline battery light intermittent
Battery light comes on intermittent when just cruising. Light comes off after about a minute or so. I put a ground wire from alternator to negative battery post. Battery light still comes on but only under heavy load. I put a ground cable from engine to frame and ground wire direct from alternator directly to battery. Any other suggestions.
Old Jul 12, 2020 | 07:48 PM
Find a competent shop and get your alternator tested, it probably has an open diode.
Old Jul 12, 2020 | 08:08 PM
Dorice's Avatar
Does the alternator need to be removed in order to get tested or can the test be performed on the car?
Old Jul 12, 2020 | 09:10 PM
They can be tested on the vehicle with the correct tester. We use them at work with our fleet of trucks.
cardhuu
May 12, 2023 08:30 PM
wintermc
Aug 9, 2020 04:18 PM
fred1845
Apr 4, 2017 07:29 AM
w0by
Jul 23, 2007 04:12 PM
Oscar
Jun 18, 2007 07:10 PM
