2008 Sky Redline battery light intermittent
Battery light comes on intermittent when just cruising. Light comes off after about a minute or so. I put a ground wire from alternator to negative battery post. Battery light still comes on but only under heavy load. I put a ground cable from engine to frame and ground wire direct from alternator directly to battery. Any other suggestions.
Does the alternator need to be removed in order to get tested or can the test be performed on the car?
