wont start
Old Jul 9, 2012 | 03:48 PM
ffire's Avatar
Default wont start
my freind ran her 2001 saturn sl out of gas. We put 10 gallons in and the car still wont start does anybody have any suggestions as to what it could be
Old Jul 9, 2012 | 04:06 PM
Check the fuel pump fuse (10A) in the instrument panel junction block (IPJB) inside the car. Turn the ignition key to the ON position, but do not try to start the car. Listen to see if you hear the fuel pump run for a few seconds, then stop. If you have one, hook a fuel pressure gage to the fuel rail, and make sure the pressure is right (40 to 55 psi)
Old Jul 9, 2012 | 11:52 PM
if like me you do not have a fuel pressure guage, correction, DID NOT have a fuel pressure gauge. After years of not needing something like that I have had enough problems to have to know what the pressure was, on a fuel injected car, having to know what the pressure is becomes important and if you do a lot of your own work, now it is time to buy one.
Old Jul 10, 2012 | 06:39 AM
possibly the junk at the bottom of the tank got sucked into the pump and either plugged the pump, lines, or fuel filter?
SL2
May 30, 2024 08:34 PM
gsutke458
Oct 27, 2010 08:47 AM
lytspdx2
Feb 10, 2010 01:49 PM
wizeguy4
Jan 4, 2010 10:35 PM
callousparade
Jul 17, 2009 02:42 PM
