What I've done to my Saturn in the last month
1.) Replaced front driver side door
2.) Valve covers 2X 3.) Modified the intake manifold (had to change the Water distribution pipe b/c it was cracked) 4.) Changed radiator ( b/c it cracked due to overheating from water distribution pipe) 5.) Water pump ( see 3 & 4) Stay tuned for more updates!!! |
Did you use the fix that someone "invented" specifically for the crack near the intake manifold?
(Post 51898)
I believe Janmar had a similar situation and used the fix successfully as well. Or I'm wrong. My memory sucks
