Transmission SLIP
Old Jun 24, 2007 | 10:55 AM
Larry2211's Avatar
Its an SL from 95 with over 120k miles with an automatic transmission. The worst problem with the transmission is when shifting into reverse that it kicks horribly and makes a sound as if you have just hit something, not to mention the engine jerks back violently. Also while in drive, there is some stuttering of shifting from 1st to 2nd gear at around 2500 to 3000 RPM. Transmission fluid has been changed but that didnt effect it at all. So im assuming itsa fully mechanical problem and I am royally screwed [img]smileys/smiley5.gif[/img]
Old Jun 24, 2007 | 01:14 PM
It's the valve body or the output shaft nut, but I'd bet on the valve body.Edited by: sw2cam
Old Jun 27, 2007 | 09:50 PM
saturntech's Avatar
i am a Saturn tech, i also agree that its either the valve body or the end nut loose or both,i sell low mileage,checked over and tested valve bodies for the s-series contact me if interested speedfreakparts@yahoo.com
Chris
gpsman4
Jan 19, 2009 04:01 PM
saturnpower
Oct 18, 2008 10:36 PM
jizake1jz
Aug 3, 2008 09:46 PM
denvermoe
Feb 15, 2008 02:43 PM
ZigZag
Mar 29, 2005 01:06 PM
